I lost my categories !!! How to restore categories ???
robert_poirotrobert_poirot Posts: 34
General situation :
I work with a 2 screen computer setup. Therefore i have the luxery to use daz3d studio 4.5 with the posing window on 1 screen, and 1 window with all the panels on the other screen.
Daz studio has not a real 2 screen option but by using "Make pane un-dockable" on one of the panel tab's the second window is created.
To be able to reopen the second window after accidentally closing it the only option is "window / workspace / save layout as"
I also use categories a lot, because that way i can organize all the content from various suppliers in a logical way.
The problem
After using "window / workspace / select layout " to restore the 2 screen workspace, i lost all of my categories, even the build in "Default categories" is gone !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! I did this verious times before without anny problems. But now disaster landed.
Does any one know how i can restore this categories , or where Daz studio stores the categories ???
Post edited by robert_poirot on
    What OS are you using, I am assuming Windows? Is there a little triangle opposite the name Categories, and on opposite Porducts?
    It looks like the CMS (Content Management Service) may have stopped running, check to see if it is a running Process in the Task manager, if not, go to tart > All Porgrams > DAZ 3D, and start it from there.
  • robert_poirotrobert_poirot Posts: 34
    Thank you,
    it was indeed the content management service. restarted the computer to make shure the situation that stopped the service from working was reset also.
    But is there a way to backup the categories ? I do a regulair backup of the library folder, but i dont think that is enaugh for a full restore.
    edited March 2013
    AdamR001 has a tutorial on backing up the Categories database.
    I'll post a link here for you in a mo.
    EDIT:
    I had given Adam an extr '0' in his username, but here it is anyway. Read through the thread and it will tell you what to backup:
    http://www.daz3d.com/forums/discussion/8028/#105548
    Post edited by JimmyC_2009 on
    In DS4.5 you can Export User Data to save your custom categories in the same format as the metadata, in your content folders.
