Redacted
cridgitcridgit Posts: 1,765
edited December 2022 in The Commons
​Redacted
Post edited by cridgit on
  • KatteyKattey Posts: 2,899
    I had same case when I tried to load some items from library. Did you try to fit them manually, via button in Parameters menu "Fit to"?
  • Richard HaseltineRichard Haseltine Posts: 111,734
    Is the CMS running? Do you have any entries under Categories or products in the Content Library pane?
  • kyoto kidkyoto kid Posts: 42,455
    ..so Autofit needs the CMS?
    The templates do, I think, the base doesn't.
    I never installed CMS and I used Autifit just fine.
    OK, then I was getting muddled with something else - in which case check that the templates are in \data\DAZ 3D\Genesis\Base\Projection Templates and if not try reinstalling Genesis Starter Essentials.
  • cridgitcridgit Posts: 1,765
    edited May 2022
    ​Redacted
  • MadbatMadbat Posts: 392
    edited July 2013
    I've posted a couple of times about the same issue. In my case something deleted the templates in the default directories just prior to the 4.6 upgrade. I'm looking suspiciously at a windoze update. I did reinstall genesis and there are templates in the poser 2012 runtime folder, but none in the Daz3d directories. Sickleyields templates are gone too. (She's the one who had me go look for the templates, otherwise I'd never have known too)
    I'll try another reinstall of the starter essentials later and see if that helps. Has anyone any other suggestions to try?
    Post edited by Madbat on
