ERC Freeze: Property list
marblemarble Posts: 7,500
edited July 2017 in Daz Studio Discussion
This is something I've never attempted before but I've often heard it mentioned: ERC Freeze.
I added some morphs to a clothing item and I want them to be applied with the movement of the limb. So I tried to follow Josh Darling's YouTube tutorial: Creating Joint Corrective Morphs on Clothing.
When he gets to the ERC Freeze part there is the morph he has just created in the properties list (plus one other which belongs to the main figure and which he de-selects). When I first tried the same procedure I got a list of every property on the figure, the hair and whatever else was on the figure. I guessed that the clothing item needs to be un-parented from the figure hierarchy so I dragged it below the figure in the scene panel. This reduced the property list to my morph plus several others that I assume the artist created.
My question is simple: should I de-select everything except my morph or do I need to know which should be selected and which should not? In other words, would I un-freeze the artist's morphs if I uncheck them in the property list before I click accept? All I want to do is freeze mine without affecting what was already there.
967 x 960 - 72K
Post edited by Chohole on
  • Richard HaseltineRichard Haseltine Posts: 111,908
    You want just your morph in this case.
  • marblemarble Posts: 7,500
    Thanks Richard. I was just wary of unchecking the others in case it reversed their setting.
