Iray morning light effect?
Toobis
in The Commons
Am doing an image where morning light shines through a window for Iray. Anyone know if a light like this is avaliable for Iray? I have browsed the store a little but with no such luck.
A Distant Light set to 3500 shining through the window? Make sure the glass is using the Thin Clear shader.
Depending on your goals, you might also look at https://www.daz3d.com/first-light-skydome-and-hdri
Or in Render Settings set Environment Map to None and adjust the Sun-Sky Day and Time.
