Stonemason's Section 4 and 5 & 6 addon - font used?
Gator
in The Commons
Does anyone know the font used for this set & texture addon?
I want to change some of the lettering for a story, but not have to replace all the text everywhere so that the font matches.
Sometimes it helps to show a screen capture of what your talking about so the assumption and legwork is taken out of the equation to anyone trying to answer.
It's possible Stone did this himself, hired someone to do it or it was done in house, it's also possible that a font was used, then modified which is not all that uncommon.
if you have some general info from looking at the character set you can try these utilities to do some detective work for you.
https://www.fontspring.com/matcherator
WhatTheFont! « MyFonts
https://www.fontsquirrel.com/matcherator
Identifont - Identify fonts by appearance, find fonts by name
Identify Fonts by Sight - Fonts.com
If you mean the font used to write Section on the walls, that looks a lot like the free font Nazalisation http://www.dafont.com/nasalization.font?text=SECTION
Wow, thanks Redz! I'm pretty sure that's the exact same font!
If not, totally close enough!
I think this IS the font Stonemason uses: Identifont - Nasalization Deluxe
