Levels of detail no longer working with Powerloader
When I load Michael4 using the Power Loader, the menu pops up with everything it's loading. On one of the tabs it asks if I want to load the Levels of Detail, so I check the boxes to confirm. (see attached image...)
Once everything has loaded, and I go to switch the Levels of Detail none of them show up in the drop down menu. (see attached image...)
Daz Studio clearly has the directories correct though because the Power Loader is able to find them. I was able to manually load the Levels of Detail using "Add level of detail". So things seem to be functioning normally otherwise...
I'm very confused, does anyone have any ideas?
817 x 396 - 51K
769 x 206 - 21K
