Tire Rubber Shader
Does anyone know if there is a tire shader that will keep the original textures?  I have old vehicles that the tires render like slicks and would like to have them render properly.
  • 3Diva3Diva Posts: 12,058
    To use a shader while keeping the original textures just hold down control and double click on the shader, when the pop-up comes up, under "Images" tell it to "Ignore". That should keep the original textures while applying the shader settings to them.
    If you're rendering in Iray, Daz has some good Iray shaders included. A decent one for tires is "Rubber - Matte". Just be sure and hold down Control when you double click it and tell it to Ignore images. :)
  • kyoto kidkyoto kid Posts: 42,391
    edited July 2017
    ...also before converting go to the surfaces tab and make sure the lighting type for the tyres is set to "Matte". This does make a difference as it affects the Iray glossiess factor.
    Post edited by kyoto kid on
  • bryanll1bryanll1 Posts: 141
    It didn't work for the WW2 Jeep, but it did work for the Roadstar.
  • KinichKinich Posts: 941
    The jeep uses a Displacement map for the tyre tread, the Roadstar uses a Bump map. The displacement transfer does not work very well and I've not managed to get a decent result after a few minutes of playing but you can put the displacement map 'jeepB3.jpg' in the Bump channel of the converted Iray shader, increase the Base Bump value (I used 10 in the attached image) and I set the Displacement to image to 'None' otherwise I get some distortion of the tyre.
    You'll really need to play with the settings to get a result you like, and it depends on lighting, image size etc to get something you are happy with, hope this helps.
    1200 x 900 - 524K
  • Richard HaseltineRichard Haseltine Posts: 111,306
    I managed to get decent results from the tyres on the jeep by using two figures - one for the wheels, using the Geoemtry Tool to select and delete everything else, and one for the rest of the model, just selecting and hiding the wheel bones. That way I could turn the Displacement Sub-division setting up enough without overloading memory.
  • Oso3DOso3D Posts: 15,115
    edited July 2017
    Another option might be to convert the bump and displacement to Normals.
    Post edited by Oso3D on
  • DzFireDzFire Posts: 1,473
    All of my vehicles have modeled tire treads and a few sets have spare tire props included. I can check later as I'm typing this on my phone.
  • nicsttnicstt Posts: 11,715
    edited July 2017
    Mec4D shaders has rubber; PBS shaders 2.
    https://www.daz3d.com/mec4d-pbs-shaders-vol-2-for-iray
    When you apply the shader, hold down CTRL and keep the original textures in the dialogue that appears.
    Post edited by nicstt on
