New Morph Files G8 Missing?
I am busy making new morphs for G8 female. It is going ok working via Hexagon. They transfer back and do loadup. I am not able to save them directly to the original G8 though and have found that I have to save as a New Character. This is all well and fine it saves me from saving mistakes I do not want to use later. But, I do need to combine and rearange some of them. Trouble is I can not find the files where they are to do this. I have just installed the newest version of 4.9 Beta 64 bit and G8.
Question is when you save a morph asset and then apply it to G8 and save as a New character, Where do the morph files go? what location?
  • TottallouTottallou Posts: 555
    Did you save as a Support Asset - Morph Asset or did you just apply the morph to a G8 and save as a Character preset?
    If saved as a support asset then there should be seperate dials for each morph in the section you saved them under
     The actual data files are under: \data\DAZ 3D\Genesis 8\Female\Morphs\Your Vendor name (You only need these if you want to delete the morphs or share with others)
    If you saved each change as a character preset as far as I am aware you would need to load each new version of G8 & save each morph as a Support Asset then open a new G8 and apply the ones you want -
    In either case if you just want 1 morph you would need to send to the completed character over the bridge to Hexagon - Reload the development G8 unmorphed then send  your character back from Hexagon and you should in theory get 1 character morph to save
    Hexagon does't like me & crashes way to often so I can't use it for this type of thing
