Daz can't find the model textures and I think I'm going to loose my mind
My problem is that Daz can't find the textures of the content I'm adding by itself. When I add content and try to open a model in Daz, it says "Could not find file Runtime/Texture/xyz.jpg", and when I direct it to the correct file, it manages to add texture for the one part that I've located and ignores all the other textures in the folder and says that it can't find them. Through digging on Youtube, it seems that Daz is supposed to set up a folder structure at Documents/DAZ 3D/Studio/My Library but it hasn't for me. The 'My Library' file is completly empty for me. Is that what's wrong?
    What is the full path to the textures?
  • Blackbirdx61Blackbirdx61 Posts: 300
    Two quick thoughts Tom Cat,
    1. Are you using the install Manager, and if so what path is set up.
    C:\Users\BB\Documents\Daz 3D\Studio\my IM library
    Now my path is a little customized because I like to keep my Install Manager content seperate from my Poser/Renderostity Content, but I have had instances where DAZ tried to load to the Users\Public\Documents\   Best practices Im told but not where I want my content to be. So DAZ did not create your My Library path under your profile check public.
    2. Are you scanning known directories for files each time you add content? I dont believe it should be necessary for IM content, but I always do anyhow. DAZ does not know where any of your poser content is until you map it this way. BB.
