Victoria 4.2 - How to apply Morphs to the figure?
Harry_2964Harry_2964 Posts: 45
I have installed the 4.2 Base figure and the ++ Morphs.
Under DAZ Victoria 4 / Morph Injections I see the "Base" and "Morph++" options which can be applied. Can you tell me how I can use them with the Victoria 4.2 figure.
I am searching and searching google, but dont find any good tutorial.
  • JaderailJaderail Posts: 0
    edited June 2012
    Parameters, after you Inject the Morphs. If you have the Powerloader installed and set it to automaticly load your morphs they will be under PARAMETERS very time you load a V4. Then you just slide the dials to add the Morphs.
    Post edited by Jaderail on
  • Harry_2964Harry_2964 Posts: 45
    Hm. I still dont get it.
    Here is what I do.
    I go to the Morph Injection folder. There I double click the +INJ V4 Base item. Then I move to the Base folder and select "BrowSqueeze".
    Nothing happens. Also at the parameters tab I dont see anything changed.
    Maybe this will help. If you look I added all my V4 morphs. That is what the Icons do. They add the morph, they do not set the morph to a value. The morph is added but still set to ZERO. If you move the slider the morph will change, and your V4 will change also.
    All my Morphs say ZERO the Icons only put the Morph into V4. I must use the SLIDER to change the MORPH.
    368 x 774 - 181K
    Well its somewhat clearer now.
    Still I have the problem to add the injections.
    According to you post if I lets say doulbe click the "Angry" icon at Morphs++ it should be loaded under parameters right? Then there I could use the slider to make V4 more or less angry.
    The problem is that when i doulbe click "Angry" it doesnt show up under Parameters "All".
    I only have other options at "Deformers, Morphs and Shapes and Morphforms". The other options work al least using the sliders.
    I have installed the 3 Base and 3 Morph++ exe files. Also I created V4 new so that this power loader thing works. Even I have no idea what it does.
  • 3DAGE3DAGE Posts: 3,315
    HI Noobisher :)
    Depending on the morph,. it will show up when you have the "Head" of the figure selected, or the main body Model selected, ..then go to the parameters, and you should see the morphs.
    If I remember correctly,.. the Base morphs should already be injected into the V4 figure when you load it.
    If you're using Daz Studio,. you should have got a "Power loader" installer, along with your V4 product.
    The power loader is a Daz Studio Script, which will bring up a dialogue window when you load the figure into the scene and can auto load the Morphs you select,. this is handy if you have several packs of morphs, like the Creature creator, Morphs++, etc.
    Hope it helps :)
    Thx for the information. This surely will make things easier for me.
    As you seem to know what you talk about, I will take the opportunity to ask you for more information.
    I consider buying The V4 and M4 shapes and the Genesis Generation X package.
    The shapes package sizes Genesis to V4. What other function has this addon?
    And second what does the Generation X package do?
    HI Noobisher :)
    The V4, M4 shapes do two things,. they give you the classic V4, M4 body shapes as morph dials, and they give you the ability to change the UV Mapping in the shader room to accept any V4, M4 textures.
    So,.. It's a real Library expander,.. if you've already bought a load of textures and clothing for V4, M4.
    The Generation X product can be used to Transfer Morphs from V4, M4 into the genesis figure.
    The Gen X addon will let you add your V4 morphs to the Genesis figure. V4 and Genesis are two different figures, genesis has morphs to let it look like a V4 but it does not have all the morphs that V4 does. So to be short, with Gen X you could ADD all your V4 Morphs ++ to the Genesis figure and make it look just like your V4 figure you designed with the V4 Morphs ++.
    Why do that you might wonder? The Genesis figure is a much better figure when it comes to Posing. When you pose V4 sometimes you will notice it just looks weird. A crease in the elbow or at the knee, Genesis was designed to pose MUCH better, and to look much more Human. The Genesis figure can also use loads of textures, V4, M4, V5, M5, and many many more. It was built to make textures look the best they can. Genesis does not have the V4 Morphs++ built into it or other morph sets for the generation 4 (V4, M4, Freak 4 ect..) But the Gen X plugin will let you add them to Genesis.
    Genesis has another great advantage. It can be any shape that has been made for it, V3,V4,V5,M3,M4,M5, and way more than that. You do not need all those other figures anymore, just the Genesis file for that Genesis figure. The draw back is as you have seen V4 has Morphs++ but Genesis will not use that pack because it was made for V4. Genesis will only use morphs built for it. V4 and other figures have lots of SHAPING Morphs that you can not get for Genesis yet. That is why Gen X and the older Morph sets are a good idea if you want to be able to do the best shapes you can ever think of doing.
    But please be sure you CHECK for a Genesis Morph set before you buy a Morph set for another Figure. V4, M4 has Creature Creator set, Genesis also has a Creature Creator set. You really need to check what can be done with Genesis before you buy anything.
    Just my two cents worth.
    Thx for the detailed explanations.
  • Richard HaseltineRichard Haseltine Posts: 111,382
    3DAGE said:
    HI Noobisher :)
    No, the M4 and V4 uv mapping come with the base Genesis, as does the ability to use AutoFit to convert V4 and M4 clothes to fit Genesis. The shapes are just the shapes, nothing more - unlike the third generation shapes which add not only the shapes but also the ability to AutoFit clothing for those figures to Genesis (but no uv maps, as the material zones are too different).
    I did not point out that the Moprhs for the FACE will only show if you select the V4 HEAD. I'm sorry I left that part out. It is a very important part to learn. Each part of the body Chest, Head, ect... will show all the injected morphs for that part. ALL may leave some out. If you wish to get the best controll of a part of the body select that body part and check in Parameters and Shaping to find ALL the dials.
  • Blackbirdx61Blackbirdx61 Posts: 300
    I've been over this thread several times, and I simply do not find the sliders in your pic. Is there a preferred order to loading the morphs? I generally load them, Base, ++, Elite, and Elite Face; morphs do appear to be loading, as the attached picture demonstrates, when I use a down loaded character, like Sondra, I get the results I want; so the script seems access the code; but If I click on an Asian Face, or Norwegian Eyes, or anything else; no sliders, ever. As usual with this application its 1 step forward 3 steps back.
    I mean seriously why is everything a game of Hide and seek with the user with this application; Still the single most frustrating application I have ever used for any purpose.
    993 x 438 - 62K
    Sondra is a custom morph, so it may be installed correctly, but that doesn't mean your other morphs are.
    1) Are you installing manually or with DIM?
    2) If you have more than one Poser-format content folder, is V4 and all morphs installed to the same location?
    edited June 2014
    Thanks, I've installed everything from DAZ store with the DIM for quite some time; I deleted my Vic cr2 file by hand then reinstalled; which seem to have done the job I have a lot more options now, and the power loader is working. Thanks again you guys in the support forum really do a great job. BB.
    Post edited by Blackbirdx61 on
  • This is my first time using these forums, I apologize if this is the wrong place to ask this question. I'm facing a similar problem in Poser. I load the V4 model in. No trouble there. I then load the V4 Morphs++ in from the poses folder. Where I get the problems though come from when I wanna change certain parameters. For instance, I can't do a full body morph. When I load a FBM, and select "Body", I'm presented with only 1 option in the deformers catagory. Usually palm size. And keep in mind, this happens anytime I inject any kind of morph or preset. Anyway, I load it up, & try to use the dile, but it won't let me set it any higher than 0, but will let me go to -1. Either way though, nothing happens. The only time it allows me to use certain morphs is when I have a specific body part selected. But even then, I'm faced with problems. For example, I select the hip. I want to change the hip/ glute size. Now when I use the diles to do this, it only applies to the hip. It doesn't then make the modifications to the thighs, abdomen, etc. Resulting in this deformation that was not the intent. But then I go to select the thighs, & there is no option there. No morphs to even speak of what so ever. I go to the abdomen, & there is also no option. Now I got it to work at one point by, again, going to each part of the body individually & using the diles, but I forgot what I did to do that. Meaning this can be done, I just don't know how. Did I do something wrong? Was V4 and her morphs installed correctly? How do I fix this? Any help with this would very much be appreciated.
  • Where is Victoria 4 isntalled? How did you install? Which version of Poser are you using? Which operating system?
    I installed V4 in C:\Users\Owner\Documents\Poser 10 Content\Runtime\Libraries\Character. & the morphs in C:\Users\Owner\Documents\Poser 10 Content\Runtime\Libraries\Pose. I opened up the compressed zip folders for both, copied the runtime folder, and pasted/ merged it with the runtime folder in the poser 10 folder. The version of Poser I use is Poser 10. & it's windows 7.
  • OK, go to C:\Users\Owner\Documents\Poser 10 Content\Runtime\Libraries\!DAZ and you should see several files and folders - double-click DzCreateExPFiles-v4.bat (you may not see the .bat in the name, depending on your Windows settings). After that try loading Victorai 4 again and injecting the moprhs.
  • Alright, I tried that. But nothing happened, I got the same result.
  • Are you sure you have only the one \Runtime\Libraries\!DAZ\Victoria 4 folder on your system?
  • Ok, I found a different !DAZ folder. I tried it, and it worked. Thanks a lot, dude.
  • just getting started and found this thread, which is now quite old.   my question is, facing these same issues to get started, where is there a link for the definitive set of instructions when adding in all these various Daz product enhancements so that I can avoid some of these errors, misunderstandings and critical install details....?   thxs
