Victoria 4.2 bundle with no V4.2 actor base figure.
I recently Bought the V4.2 bundle.  I was provided with V5 and V6 actors. But there is no V4.2 in the mix.  I purchase the product to be able to use V4 clothing.  It clearly stated that the bundle is  a V4.2 product, and said nothing about including V5 and V6 .   What's up with this?  Did Daz providd me the V5 And V6 figures because the V 4.2 figure is no longer available ?  Does anyone have this issue.
  • Richard HaseltineRichard Haseltine Posts: 111,371
    Victoria 5 and 6 are not aprt of the Victoria 4 bundle, they will be separate purchases. Victoria 4 is Poser format, so look to see if the abse figure in in the Content Library pane under Poser Formats>folder isntalled to>Figures>DAZ People.
  • edevaldesedevaldes Posts: 2
    Thanks for your response.  I looked in the poser content.  I searched the rest of the libraries as well.  There is, under poser format- figure-Daz victoria,  various additions ,such as clothes. But there is no Vicotria V4.2 base figure anywhere.  I agree that the Victoria 5 and 6 would come from a seperate purchase.  However, I have  never have made a spcific  purchae for either of these two figures, but they did appeared in my smart content as actors after I installed the V 4.2 pro bundle.
    I tryed to install the Visctoria 4.2  base figure content manually into the Poser Library, and the Daz 3D library without sucess.  Furthermore,  the IM has the V4.2  base figure ready to install.  But  reads " failed to install" when I try to intall it using the IM.  I'm clouless why a Vicoria 4.2 pro bundle, that  shuld obviously include the V4.2 base figure, has instead possily provided me with both the Victoria 5 and 6 figures, but failed to install the intended purchase of victoria 4.2 base figure.
    If actually it work so, you are really lucky guy, daz miss offer you.  I feel,, but any way, how you install contents first? if you use DIM, you can check your installed package and file path, , and which file are included in downloaded package. and may better use DIM un-install them once. install somethign by DIM ,then install manually same package, may often course problem.
    eg,, my purchased Victoria 4 pro bundle was appendix of Carrara which I bought long time before. (I do not clear remember, when I got them with witch package)
    but I can serch Victoria 4 contents which I bought for daz studio by DIM. then it show clear which files are included in  separate package. and where hose files are installed.
    if your package  include Victoria5 or Victoria6, it means daz offer wrong bundle I think. or you need to check your "order" from your account of daz shop.
    then check which product are actually offered.
    Can you link to the actual product you purchased and installed?
    Thanks for your comments.  I resoved the problem. Earlier I inadvertently changed the file path in the install maneger. I returned the paths back to the defolt settings, and I was able to install the V4 base figure. I still don't know where the V5 and 6 came from, but if it's a gift I'm not complaning.
