Menu disappeared
When i try menu item edit/object the rest of the pull-down menu has vanished and I only see "change"parent".
It just happened and i can not figure out how to restore this.
I have another install from dazstudio on an old computer and the menu is normal. I need this menu to add smoothing to old objects.
it is very silly, but can anyone help??
  • Richard HaseltineRichard Haseltine Posts: 111,842
    You can reload the default menus in Window>Workspace>Customise, or simplt reload your layout in Windows>Workspace>Select Layout.
  • My menu options disappeared. I can only see Tools and Windows. My Window menu only shows "Panes" option and nothing else. Also the software does not react to commands such as Ctrl+R (for rendering). Any help pls? I use Windows, insatlled daz studio some 3 months ago. Thanks!
    If you can't see this to make a selection, I'd try rebooting the computer. Then if you still can't see anything, maybe reinstalling the program is in order?
    669 x 339 - 33K
