Probleme Lipsynch
When i click on analize in lipsynch it gives me message
"some channels defined in the current configuration file could not be found on the figure. lip-syncing may not be as accurate as expected. see the log file for details"
please help !! and thanx
  • Richard HaseltineRichard Haseltine Posts: 111,475
    LipSync has a file, somethign.dmc, which lists which morphs should be used for which phonemes in creating the animation. It appears that you do not have, or are not using, the .dmc file for your figure or that some of the morphs used are not being found. Which figure are you using?
  • reghainawfelreghainawfel Posts: 0
    edited July 2017
    I use genesis.dmc and I already try others same result
    Thank you for your attention.
    Post edited by Chohole on
    I remember, for genesis2, DAZ already offer official DMC separately, you can find it in DIM. then you can load it from directory where your DIM installed.
    (your daz library =DIM setting) /General/Mimic configs/Genesis2.DMC
    I do not know daz connect already offer it or not.
  • I am facing the same issue and I still cannot find a way out of this error "some channels defined in the current configuration file could not be found on the figure. lip-syncing may not be as accurate as expected. see the log file for details" @kitakoredaz I cannot find the the file that you mentioned above. Is there any alternative to this, I mean any plugin that can help us lipsync properly in Daz 32 bit or Daz 64 bit. Anyone please help because I want to make a video for one of my songs and I am having a hard time with this lipsync feature. I know I am asking too much but can somebody please do that for me I am not on a big budget right now so I cannot pay the person who helps me, but I can promote that person on all my social media profiles and give them proper credit in my video for sure. I hope I find somebody who can help me in any way. Thanks and happy video animation smiley
