G3 shoes to G8
Whenever I try to autofit shoes from any figure to G8 I get a twisted mess.  Is there an easy way to do this?  I have some G3 shoes I really would love to be able to use on G8
  • GnotMeGnotMe Posts: 131
    Same question that KristinF has.  AutoFit of GF3 clothing to G8 works fine almost every time, but there is no Footwear/SHOE choice at all, and consequently GF3 shoes simply never fit quite right, although with extra time spent it can sort of look ok.
    Is this a limitation due to differences in GF3 and G8 feet, or an oversight with Autofit ?? Will there be a fix?
  • nakamuram002nakamuram002 Posts: 827
    edited July 2017
    If you are trying to convert flat shoes, stockings, socks, or panty hose from G1, G3, G3 to G8, select "full body" when doing autofit.  That has worked well for me.  High-heels are another matter.  There was another thread on this subject:
    https://www.daz3d.com/forums/discussion/178991/g3-shoes-for-g8-node-weight-map-brush#latest
    The techniques described seem to work reasonablly well, as long as you use the weight-map brush properly.
    Post edited by nakamuram002 on
  • KristinFKristinF Posts: 71
    Thanks so much, I will check it out.
