M4 Creature Creator morphs in Poser?
false1false1 Posts: 46
Hi folks. Anyone having luck installing M4 Creature Creator morphs in Poser 8/Pro 2012 on Mac? Bought the package about 2 weeks ago and keep getting "required file not found" error when I try to install. I tried installing directly into an M4 folder and tried installing into the main runtime no luck. I tried asking Daz for help but after their first answer didn't work they decided to ignore me.
Does this package only install in Daz studio or on a PC perhaps?
    When installing the package, choose DAZ Studio as the target application, it will make no difference at all to what is installed, but the installer will not look for Poser.exe.
    You must install to the same folder as the M4 base is installed to as well.
  • rdudarduda Posts: 586
    Make sure you have all the updates to poser! I couldn't load any M4 or V4 morphs because I didn't update Poser once.
  • false1false1 Posts: 46
    Thanks folks,
    I've tried all the suggestions mentioned here and just now tried updating Poser 8, installing into Daz Studio (this product only has a single installer for Daz and Poser whereas others I've used have separate installers). I've tried installing M4 into the main Poser or Daz runtimes but no luck. The only thing I haven't tried is the PC installers. I'm on Mac.
    Perhaps my M4 runtime is corrupted. I've long since lost the original installers though it's worked perfectly so far or maybe it has to do with what I've read here: http://forum.runtimedna.com/showthread.php?70623-Creature-Creator-Morphs. I'd be tempted to buy a fresh version of M4 but don't want to throw good money after bad.
  • fixmypcmikefixmypcmike Posts: 19,741
    Where do you have M4 Base installed? That's where you need to install the morphs.
    Good news. I located my original M4 installers and created a fresh runtime folder with morphs. I initialized the items then installed Creature Creator. Worked like a charm so I installed the add ons too. No problems. I want to thank all for the help because it helped me realize I needed to start from scratch.
    Now that it's all working, let me gush a bit and say this product is an excellent value considering that it allows so much variation in one package. I'll have to pick up the V2 morphs as well.
