Issues installing C8.5 Beta 172..help SOLVED :)
Kharma
Initially I had just the Beta installed which installed to Daz3d/Carrara8 but when I tried to install C8 Pro after it wants to install to the same directory. So \i uninstalled the \beta and then installed C8 Pro now am trying to reinstall the beta version which wants to remove the C8 version and install to the program files/daz3d/Carrara8 directory.
I even created a new folder called Carrara8,5 Beta but it still wants to uninstall the C8 version..I even reset and redownloaded the C8.5 Beta to be sure it was the correct copy but can't install without removing C8. Is this normal can you not run both copies and if so how do I get past this to install the Beta so I can use Genesis in Carrara?
Thanks for any help on this
running Windows 7 on Pc 64 bit
EDIT: I have succeeeded in installing both versions..thanks :)
