Iray Crash... (4.9.4.117)
I noticed earlier my render kept restarting once reached 70% more or less.
I spotted that in the log:
2017-06-28 19:40:07.923 Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Rendering...<br />
2017-06-28 19:40:07.936 Iray VERBOSE - module:category(IRAY:RENDER): 1.5 IRAY rend progr: CUDA device 0 (GeForce GTX 970): Processing scene...<br />
2017-06-28 19:40:07.938 WARNING: /src/pluginsource/DzIrayRender/dzneuraymgr.cpp(307): Iray ERROR - module:category(IRAY:RENDER): 1.7 IRAY rend error: OptiX Prime error (Device rtpModelUpdate TL): Unknown error (Function "RTPresult _rtpModelUpdate(RTPmodel, unsigned int)" caught exception: Encountered a CUDA error: cudaMalloc(&ptr, size) returned (2): out of memory, [15466617])<br />
2017-06-28 19:40:07.938 WARNING: /src/pluginsource/DzIrayRender/dzneuraymgr.cpp(307): Iray ERROR - module:category(IRAY:RENDER): 1.5 IRAY rend error: CUDA device 0 (GeForce GTX 970): Scene setup failed<br />
2017-06-28 19:40:07.942 WARNING: /src/pluginsource/DzIrayRender/dzneuraymgr.cpp(307): Iray ERROR - module:category(IRAY:RENDER): 1.5 IRAY rend error: CUDA device 0 (GeForce GTX 970): Device failed while rendering<br />
2017-06-28 19:40:07.942 WARNING: /src/pluginsource/DzIrayRender/dzneuraymgr.cpp(307): Iray WARNING - module:category(IRAY:RENDER): 1.5 IRAY rend warn : All available GPUs failed.<br />
2017-06-28 19:40:07.942 Iray INFO - module:category(IRAY:RENDER): 1.5 IRAY rend info : Falling back to CPU rendering.<br />
2017-06-28 19:40:07.942 WARNING: /src/pluginsource/DzIrayRender/dzneuraymgr.cpp(307): Iray ERROR - module:category(IRAY:RENDER): 1.5 IRAY rend error: All workers failed: aborting render<br />
2017-06-28 19:40:08.387 Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00300 iterations after 2647.862s.<br />
2017-06-28 19:40:08.446 WARNING: /src/pluginsource/DzIrayRender/dzneuraymgr.cpp(307): Iray ERROR - module:category(IRAY:RENDER): 1.0 IRAY rend error: Scheduler was aborted for restart and needs to be restarted<br />
2017-06-28 19:40:08.450 Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : CPU: using 16 cores for rendering<br />
2017-06-28 19:40:08.450 Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Rendering with 1 device(s):<br />
2017-06-28 19:40:08.450 Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : CPU<br />
2017-06-28 19:40:08.450 Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Rendering...
What does it means and is there a way to solve that ?
Thx.
