Help importing a 3rd party hairstyle
Hi
I downloaded a 3rd party hair style and I am having trouble importing it to DAz studio. I'll preface this by saying I am a beginner with Daz studio. I am using Daz 4.9.  The hairstyle I downloaded is a zipped file, when unzipped it countain a single folder called 'Runtime', with several subfolders. I belive this has to be installed manually? (Copy the files manually to some Daz directory)  Does anyone  know the correct Daz directory to copy it to?
AND do I copy the Runtime folder in its entirety into the DAz directory? Or do I open each subfolder under Runtime, and then copy every individual file somewhere into the Daz directory? If you could point me to a tutorial i would apprect it.
Thanks!
  • Richard HaseltineRichard Haseltine Posts: 111,325
    The Runtime folder needs to be merged with the Runtime folder in your content diectory. Files in a Runtime only will be Poser-format, so you will need to look in the Content Library under Poser Formats>folder you installed to>Figure or Hair probably>some folder. The materials will probably be in the Pose library, but may be in the materials library.
