PBR Surface Copy Bug?
I don't know if this is a bug or intended behavior, but I always encounter the same problem when copying PBR surface properties (Iray Uber base) from one surface to another.
All properties get copied, except one, the Thinned Wall on/off property.  If this property happens to be turned off in the copied-to surface, it stays off, even when the copied value should have been turned "on".
I have to manually check to see if this property is turned on because it never seems to get set correctly.  All versions of Daz Studio seems to have the same problem.
  • nonesuch00nonesuch00 Posts: 18,841
    Never notice that personally. I'll have to pay attention next time.
  • Seven193Seven193 Posts: 1,147
    edited June 2017
    It's not noticeable in Preview mode, but when it gets rendered, there is a very noticeable mismatch in surface color.  Turning Thinned Wall  back to On fixes the problem, as it never got copied over.
    Post edited by Seven193 on
  • Richard HaseltineRichard Haseltine Posts: 109,541
    I'm not seeing this, using a couple of primitives.
    I actually experienced same thing many times already. It happend for me,, about non daz product  geo grafted . (to be frankly said anatomy)
    but  it  happen about geo grafted item which I made too.. then I manually change Thin wall .(I did not report it, because I suspect if Geo grafted item need to set volume so)
    edited April 2019
    I also couldn't duplicate it, so never reported it.  Maybe the fault is with user-created objects, and not specifically Daz.
    I  thought,  if current version  remove this problem. but after apply mat,, then when I reset both surface iray shader  "thin wall" property"
    now it can not copy and paste about thin wall value as same as before,  Though I could not confrim, what case  actually cause this issue.
    some mat could copy this property without problem, but some skin mat can not (maybe sss other property effect , I think, and daz added it about current version too)
     now I can re-produce same problem about current prodcut build.  actually there is  still remain problem.  I test with daz  iray skin, and grafted item. (hand made)
    1225 x 835 - 142K
    1177 x 781 - 121K
    876 x 749 - 116K
    1217 x 820 - 141K
    Ah I see..  if the mat preset saved with "on" , maybe default value change as "on",,  then if I copy surface (default OFF) , then paste to another surface (saved as default ON)
    DS seems can not overwrite about "thin wall".
     I just test two primitive which apply iray shader,, then change default value of Thin wall (iray) property ,by parameter setting.   one is "on" another is "off" ,
    they can not copy and paste correctly.
    I do not clear remember,, how I save the grafted item,, but it seems save as default "on", then maybe my anatomy product was saved as "on" too.
