Any one else having skin shader problems with RawArts Honey character?
I broke down and bought RawArt's Honey Character last night.  Used DIM to download and install her and fired DS up.  Loaded her into a scene and then applied the Green skin shader.  Did not appear that the shader applied so I went ahead and tried to render her and no skin color change.  I also see an error in the log file that states " WARNING: cloud\dzcloudtasknotifier.cpp(178): peer performed orderly shutdown errno=0" right after trying to load the skin in the log file.  Not sure if I have a setting off or not.  I am using DS4.9.4.117 and also did the Victoria 8 update befire I installed Honey last night.  Any one else having issues with the skin shaders for Honey?  TIA
  • RawArtRawArt Posts: 6,216
    The skin tone will not show changes until you render.
    Here are the notes from the readme:
    Tone effects must be applied After all make-up choices are applied.
    To apply the tone effects, all figures (ie Genesis 8, antennas, etc) that that the effect is wanted to apply to must be selected in the scene tab and all appropriate surfaces also must be selected before clicking on the tone effect.
    Make sure you have all the figure parts and surfaces selected when you apply the tone settings.
    Then it should render fine
  • Thanks.  I got it to work
