IRAY shaders broken since DAZ Studio Upgrade
So there I was ALL my purchased IRAY shaders working wonderfully and I upgrade to the newest DAZ studio (I had the the most current version unitl the new release.
NOW all my IRAY shaders are broken.
They either plainly do not work or only partially work.
And lord help me if I change my mind on a shader and try to apply something else! Then I will get an bizarre combination of the two.
Right now I have about 150$ worth of DAZ purchased IRAY shaders that are absolutely useless.
Is there a setting? Some setting I'm missing in this new "upgrade"?
  • HavosHavos Posts: 5,671
    Do you have any examples of which shaders are broken?. I also have a mass of Iray shaders and none that I have tried so far in the latest version are misbehaving. Do you mean applying via Smart Content is not working? If so, you might need to reset your content database, and then reimport everything again to fix this.
  • I mean I go over to the Daz Library on the left of the screen go down to shaders, choose one and double click like I always have done and random destruction begins.
    Which tab is the DAZ library?, do you mean Content Library or Smart Content? These are two separate tabs.
  • I reset the content database and things seen to be proceeding nicely.
     THANK YOU!
     THANK YOU!
    Great, I'm glad you sorted it out
