Problem with the morphs - The figure becomes small
Hi. I have a problem with the morphs. I have tried to create the Morphs but I can not find the form. I have done the following:
1 - I took the base Genesis 3 (Male) and put the figure with the right eye closed (I use pose controls).
2- I export it with low resolution as OBJ.
3 - Then I use the Morph Loader and I load the OBJ file with the eye closed.
4 - The problem is that when I apply the morph and slide the bar my figure becomes small.
Which is the error?
Thanks.
Did you make sure that all of the morphs, transforms and poses where zeroed except for the single morph that you are trying to export?
everything that is not at zero will come back in as part of your morph.
So you export with 1% scale.. but import it default scale.
without you plan to make morph in another app, , you just keep export setting as DAZ default .
it means export 100% scale, then import 100% scale. (or 1% export, import 10000%, in morph loader ,,by click show individual setting, then change scale)
Thank you very much!!! It is done. It was that I had to put the scale in 100.
