A couple of problems with Smart Content
On some occasions my Smart Content downloads will not start, so I dealt with that by "kickstarting" it - I clicked on a random product and updated the meta data. However this is now not working either, I have internet connection and am having no issues with it.
The other issue is that some products will not update. I have had the Jester Outfit since it came out and it will not update or if it has it still stays in the list - this is months now, however, it seems to work alright in renders. This has happened before and I have uninstalled them and reinstalled them, then upgraded to no avail. Then one day they are gone from the list and installed properly - very frustating.
Now the install of Victoria 8 is failing each time I try it.
Does anyone have any ideas?
  • frank0314frank0314 Posts: 15,088
    Are you installing your products with DIM? If so go to your Installed tab and select the checkbox next to "Products" which will select everything in your library, then right click and select "Re-Import Metadata" and see if that kicks the products through. This can also be done within Daz Studio if your installing manually.
  • Kevlar31Kevlar31 Posts: 63
    I just go into Smart Content, click the Available tab, then double-click on the available items. It used to work fine - now?
