hi i have a ? that i need help with bad
lasagnamanlasagnaman Posts: 1,001
when you pin bodyparts like what i do is pin the feet and toes  , how do you save it so the next time you open your scene again the bodyparts stay pinned and you dont have to do it again and its set , so when i click on the hip he or she bends there knees   pleasssse can someone help me with this  thanks so much
  • EtheralEtheral Posts: 91
    I dunno how to save the translation/rotation pins but I know the ActivePose Tool pins presist across saves. Though I know it's not the same thing.
  • gederixgederix Posts: 392
    Active pose pins persist through saves, universal tool pins do not. To use the active pose pins you will need to open the tool settings pane as that is where you toggle active pose pins on and off. You should also add the tool settings pane to your UI so you can get to it quickly/easily.
  • lasagnamanlasagnaman Posts: 1,001
    thanks o much my friend
