Daz3D to ZBrush Help
lunarscapeslunarscapes Posts: 20
Does anyone know how to manually instal GoZ for ZBrush 4R8? I cannot figure it out. I don't know what files to put where. I'd appreciate it if anyone could help. And yes, I have uninstalled GoZ for 4R7.
Post edited by lunarscapes on
  • Richard HaseltineRichard Haseltine Posts: 111,168
    Uninstall GoZ, update the ZBrush path in the Applications tab of DIM's preferences to point to R8, and reinstall.
  • lunarscapeslunarscapes Posts: 20
    edited July 2017
    It's still not working, unfortunately. I tried doing exactly what you said. No matter what, it always says "unable to connect to ZBrush, check the installation" inside Daz3D. And no matter what, the ZBrush files are always installed under Users (I don't remember if it's supposed to be like that?)
    Yes, the files for GoZ go in the user profile - it's an odd tool, it isn't exactly a plug-in (which is why the bitness does matter) but does most of its work via sahred files as afar as I can tell. You mightt ry removing the GoZ Projects folder.
  • Thank you for responding, could I ask what folder is the projects folder?
  • linvanchenelinvanchene Posts: 1,386
    edited July 2017
    It is located in
    C:\Users\Public\Pixologic
    compare:
    https://www.daz3d.com/forums/discussion/comment/2611986/#Comment_2611986
    Post edited by linvanchene on
    There should be a "GoZProjects" folder in C:\Users\Public\Pixologic\
