4.9.4 Why still no DIM?
I only use DIM.
Why the latest release 4.9.4 is not available as an auto upgrade via DIM? Gen 8 already is.
  • It is and has been since release. I don't understand why DIM on your end is not showing it for you to download and install.
  • DoctorJellybeanDoctorJellybean Posts: 10,089
    Do you have the previous release installed (4.9.3.166)? Read this post and see if that helps:
    https://www.daz3d.com/forums/discussion/comment/990681/#Comment_990681
  • EtheralEtheral Posts: 91
    I have it on mine.
    Do make sure that you have at least the following in DIM checked (Settings - Downloads):
    Daz Studio 4.5+
    General
    Software
    Plugin
    Windows or Mac (Depending on your OS)
  • SamanthieSamanthie Posts: 308
    When I started DIM using the desktop shortcut it showed up under product updates at the top inside DIM. There are three updates Daz Studio 4.9, GoZ for Daz 4.9 and Install Manager default filters
  • boisselazonboisselazon Posts: 458
    I know all of this, all is checked in the DIM poreference, and....nada sad
  • Charlie JudgeCharlie Judge Posts: 13,624
    In DIM check to see if you have DS hidden. I had hid the previous release because I didn't want to install it. So, when 4.9.4 came out I had to display the hidden "To be Installed" files for DS and unhide it in order to see it to download the latest version.
    Can you download and install it from your Product page?
    Optionally, you can locate, download and install DAZ Studio Pro from the Product Library [once you are logged into your account] by entering "DAZ Studio 4.9 Pro" into the text field near the top left of the page and clicking the "Filter" button, or by clicking here. Then, simply click the green "download & install" button to launch Install Manager with an appropriate filter.
    No, I just can't. I even deleted the IM00013176-02_DAZStudio49Win64bit.dsx and zip in the DIM directory (those are 4.9.3). Restart dim nada
    click install & download in product page nada, nothing is hidden. It's really getting on my nerve as everything worked fine the past 2 years
  • frank0314frank0314 Posts: 15,090
    Have you done a hard refresh of DIM? Hold down CTRL while hitting the refresh button in DIM. I've had to do it a couple times and then the stuff showed up.
  • I had the same problem as well. For me, DIM was not showing hidden files even though "show hidden files" was checked. I resolved this issue by manually searching for the SKU of the product. Then it magically appeared in the list again.
    In your case, try typing this into the DIM search: "sku::13176" (without quotes).
    -P
  • Richard HaseltineRichard Haseltine Posts: 111,256
    The zip has nothing to do with a diect download from the Product Library page https://www.daz3d.com/downloader/customer/files#prod_13176 Click the blue Download button for your desired vesion in the Manual column
