Changing sets in a scene
BnomSandyBnomSandy Posts: 7
So, i started this scene with Sarsa's Vandalized version of the Park Tube set. Now I'd like to revert back to the original Park Tube set, but Daz Studio will not allow me to load another "scene" into the existing one. I tried deleteing the vandalized version, but I cannot seem to find a path to removing the vandalized version and replacing it with the original without having to repose my figures, lights, etc. Surely there is a way to do this, yes?
Any pointers would be appreciated. Thank you.
GhostDog
    edited February 2013
    I think,, the original Park tube station has ds material preset file.
    and Sarsa’s Vandalized version of the Park Tube , seems material preset file only. is not it?
    I think,,select the root node cr2 in scene tab,,
    then apply •DAZ Studio Material presets (DS) files of original Park tube again.
    it may change the material of set.
    (And you can delete the scene, in scene tab,
    by select each figure (prop) > right clcik and remove it.
    I think each parts of the sets are grouped as one , so you may need select root , then
    right click>remove or from top menu> Edit>delete >selected items.
    hope it may some help you, but I do not have the tube set, so I can not check it ^^; sorry.
    (I have some park side sets, and it work as I said)
    Post edited by kitakoredaz on
  • JaderailJaderail Posts: 0
    As Kit points out all you should need to do is Change the Texture Sets not the Full Prop set. Select the Prop in your Scene Tab and then use the Clean DS Textures one at a time until all have be replaced.
  • fixmypcmikefixmypcmike Posts: 19,742
    Changing textures is the way to go here, but if you did need to replace the props, right-click on the icon and choose "merge"
  • BnomSandyBnomSandy Posts: 7
    Thanks for your replies. Turns out the materials to turn it back to normal are under a folder labled "Vandalized in the library, so I never looked, hehe. Thanks again.
