How to keep pregnant/large bellies from getting squished in the crotch area
Hi,
I've stumbled across a problem with the Gen 3 female models. If they have a large belly, the belly will get squished in the crotch area, especially if bend the abdomen and/or thighs. The crotch seems very rigid and doesn't really react to the shape of the belly. Is there any way of fixing this? See attached render of the issue.
816 x 624 - 667K
Spanx?
I second this. HAs anyone got a solution?
DFormer?
Okay that is an embryo of an answer, can you develop a bit? Please please?:)
THANK YOU SO MUCH!:-) This (Dformer) finally solved my issues!
Second.technician: I recommend you check out these tutorials:
Note on clip 1: you need to select the genesis model itself to apply the Dformer (selecting a bodypart doesn't work).
Note on clip2: I find his weightmapping technique works the best for this case.
Alrighty, I will definitely look into this. Thanks for sharing the videos :)
