Victoria 8's Eyebrows not visible in Texture Shaded preview mode
ArgleSWArgleSW Posts: 161
Is there a reason why Victoria 8's eyebrows are not visible when running the editor in Texture Shaded preview mode? The only way to see it is in NVIDIA Iray preview or doing an actual render. Not that its a critical issue but it would sure be nice to see the eyebrows.
  • ArtiniArtini Posts: 10,900
    edited June 2017
    They are visible on my computer. Please note, that eyebrows are not loaded automatically with Victoria 8.
    You need to load them on Victoria 8 in your scene from the Content Library (second image).
    1781 x 1127 - 253K
    331 x 491 - 37K
    Post edited by Artini on
  • ChangelingChickChangelingChick Posts: 3,441
    It's a function of the shader. I don't know exactly why, but anything in the Diffuse Overlay channel won't show except in iray preview or a render. For V8 this includes her painted eyebrows and makeup options. The eyebrows that you load in are fibermesh ones that you can use instead of the painted ones, which is why she has 2 options for each of her makeup styles-- one with and one without painted eyebrows.
    I should add, this is a common issue with using masks to color parts of an image. Same thing happened with 3DL shaders with masks and color channels attached, and even in Poser a mask/color setup would not show in preview.
