Transfer Utility and Genesis 8 Problem
Jim_1831252Jim_1831252 Posts: 728
I have finished up a quick dress for Victoria 8, but I'm having trouble with the transfer utility when I go to rig. As you can see from the first image, the mesh is a reasonable fit on import, but after I use the transfer utility the dress "floats". I have used the utility many times for fitting items to G/2/3, but I am stumped with this problem. Am I missing something, or is this a bug? To me it seems the transfer utility thinks Victoria 8 is much taller than she is. Could this be an issue with the template transfer utility is using?
Post edited by Jim_1831252 on
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,435
    is that V8 rather than the G8F base?
    also there is a developers rig version
    I do not get V8, but If Victoria 8 morph change scale node, (usually root node), (you check parameter of node), it may cause probloem when use TU with remove source shape from targe option.. TU not count scale. (I do not know if ds up-date it or not for each version, may change)
    at least remove scale from V8, then make clothing mesh witch fit to V8, (non scale) use reverse option. with V8 FBM. (set it as source shape)
    But I believe, make mesh for zero base G8female , then auto-follow morphs by Victoria 8 , more easy and usually work best.
    (after fit with base shape well,  you can overwrite generate morph (FBM FHM) to fit V8 better.
  • Jim_1831252Jim_1831252 Posts: 728
    Thanks guys. I actually loaded in the base dress as a morph and dialed it in to reverse the offset.
    @ th3Digit, it is V8, not G8F. I don't have the developer rig.
    @ kitakordaz, I'm sure that is not as complicated as it sounds. To test the FBM.FHM thing, I dialed those morphs out of the dress, but it remained "floating".
