A5-Azumi
LevanahLevanah Posts: 0
In my Poser library it installed the material mc6 files within the Pose directory and thus they don't show and I had to move them manually in the right place. Please check if this is the case for everyone. Thanks..
  • Richard HaseltineRichard Haseltine Posts: 112,021
    Which version of Poser? They should show in Poser 8 and later. In any event, if you wish it changed you need to make a bug report to bugs.daz3d.com in the Content area (Separate log in, it doesn't use your store/forum account, so you will need to register if you haven't before).
  • KeryaKerya Posts: 10,943
    Ehm, Richard: mc6 don't belong in the pose folder, they should be in the materials folder.
    It's not a "wish" to change it, it is a real bug.
    Current versions of Poser allow file types to be in the "wrong" library, and allow material files to be used in the Pose room, as far as I know - I think I've used that with MC6 files in the Figure library (grouping content the way it is in DS, instead of across multiple libraries). But in any event, a bug report is the thing to do.
  • LevanahLevanah Posts: 0
    Yes, in PP2012 it will display, but if you use external library python scripts like I do, it won't display and so I think this should be taken into consideration and maybe this also isn't valid for older versions of Poser?
    Well, Genesis won't load in older versions at all - but I would definitely make a bug report pointing out the issue for users of alternative library managers.
