Victoria 8 and wardrobe from V5,V6,V7 do not show up.
From what I read V8 should be able to use wardrobes from older versions, but the do not show up in the wardrobe pane. I unselected V8 and grabed the clothing items and drageed them to her, it responds like doing it with other versions of Victoria; well sort of some clothing items do not conform to her well. Some are way off! How do I fix this or make the older wardrobes work? Some of the hair is real messed up! I got this version so I could mix old wardrobes and new ones.
  • Richard HaseltineRichard Haseltine Posts: 111,382
    No, if you have Filter by Selection set the older items are not (at least currently) marked as compatibkle so they won't show. When fitting them after loading, are you setting the correct base figure in the AutoFit dialogue?
