Genesis 8 Default Figure Will Not Load
Is anyone else having this problem?  The category thumbnails are missing, and when I double-click to load the figure, I get the attached error message.  So far I've uninstalled and reinstalled Daz Studio.  I thought I'd check here before starting a ticket.
Thanks!
816 x 840 - 65K
412 x 100 - 5K
  • fastbike1fastbike1 Posts: 4,085
    No problems at my end.
  • Richard HaseltineRichard Haseltine Posts: 112,078
    Have yopu tried uninstalling and reinstalling - closing DS between the two if you use Connect. There was an issue, not directly with the Starter essentiakls but with the Power Pose templates, and fixing it may have messed the metadata for the Genesis 8 Starter Essentials.
  • cridgitcridgit Posts: 1,765
    edited May 2022
    Redacted
    Post edited by cridgit on
  • cridgit said:
    Yes I had the same problem yesterday, and opened a ticket. Its solved now.
    Make sure you update DAZ Studio first as you need the G8 starter essentials. Then I did the following:
    1. uninstalled the product (right click uninstall)
    2. updated metadata (select all products, right click update metadata)
    3. reinstalled the product
    4. updated metadata (select all products, right click update metadata)
    5. refreshed the product (right click refresh)
    Thank you, sir! You are a life saver.
    Talk about having to do the hoky-poky just to get the thing to work..
    edited May 2022
    Redacted
