Measure Metrics not included for G8 / V8?
Does measure metrics work with G8 / V8?
There is no measure metrics folder for G8 / V8 after install nordoes there appear to be any PBMs either in G8 or V8 that can be used as the perameters for measure metrics. Is there somehing wrong with G8 / V8 or is it measure metrics?
My measure metrics began to act odd after the latest DS update -- rather than changing the meaured value when you change the meauring unit to reflect the new measuring unit you have to check then unchck the metric to be measured before the correct unit value will display.
  • tj_1ca9500btj_1ca9500b Posts: 2,057
    edited June 2017
    There was a MM update in the DIM this morning, but I haven't downloaded/installed it yet.  I wanted to install the new 4.9.whatever it is by itself, so as to not 'confuse' anything, and take it for a test drive before updating anything else.
    As to whether the new update applies to G8, I don't know yet.  I'm sure others may have, and may be able to answer your question.  Mainly I'm just pointing out the MM update that was released in the last few days, in case you haven't noticed it yet.
    Post edited by tj_1ca9500b on
  • gishzidagishzida Posts: 27
    Thanks for the reply!
    I've removed MM and re-installed a fresh copy about 3 times... no luck. It still does not explain the missing folders / parameters... I suppose I'll have to wait to the first patch... I don't like 70 inch tall characters...
  • JamesJABJamesJAB Posts: 1,766
    Well, you can always do it the old fashioned way....  Make a primitive cylinder that is the size you want to make the character. and work from there. :P
  • Richard HaseltineRichard Haseltine Posts: 111,369
    Rob has said he plans to update Figure Metrics for Genesis 8, it's a question of finding the time between al the development work on DS and so on.
    Thanks for the reply... Hope it's sooner rather than later.. My character creation workflow starts with Figure Metrics...
