G8 Skin Material Advancement
Is this specifically a G8 feature or is it an Iray shading option that will work with G3 as well?
  • Richard HaseltineRichard Haseltine Posts: 111,390
    The sahder would work, but as it's a diffrent set up the maps might not (I haven't looked yet to see what is involved).
  • The sahder would work, but as it's a diffrent set up the maps might not (I haven't looked yet to see what is involved).
    Thanks for the reply. Do you know if the new shadere auto applies after the latest update, or would you have to apply it to you a G3 figure? If so, where would the shader be located?
    Iray Uber Base - I haven't looked to see if the new properties appear by default on saved settings, but I would expect so.
