Username Change and Install Manager issue
I recently changed my username and now when I log into DIM with the new username, it shows all of my purchases and still need to be installed, yet in Studio they are installed. How to I get manager to reflect my current installs under my other username tha I had?
    Did the email or password change?
  • Did the email or password change?
    Yes email and password changed.
    Since Install Manager doesn't know it's the same account, it isn't looking at the information for the "other" account.  If you go to C:\Users\[username]\AppData\Roaming\DAZ 3D\InstallManager\UserAccounts you shoud see a .ini file for each account.  In the one for the "new" account you can add a line in the [General] section reading:
    OverrideManifestDir=Q:/DIM/ManifestFiles
    (with the path to the ManifestFiles folder for the "old" account, I've modified mine so I don't recall what the default is).  Note that the separator is a forward slash rather than a backslash.
  • Since Install Manager doesn't know it's the same account, it isn't looking at the information for the "other" account.  If you go to C:\Users\[username]\AppData\Roaming\DAZ 3D\InstallManager\UserAccounts you shoud see a .ini file for each account.  In the one for the "new" account you can add a line in the [General] section reading:
    That did not work for me.
    Did you have DIM closed when you made the change?
    I just reinstalled everything.
