Parenting in animations
hrpschrdhrpschrd Posts: 180
edited June 2017 in Carrara Discussion
I think it is true that one cannot change parenting (or hierarchy) in the midst of an animation. The parenting starts at 0 seconds.
So how would someone, for example, sweep with a broom which catches the debris on the broom and carries it with the broom?
If you create a target helper on the broom and point to that with the debris at some later time, would the debris "attach" as the broom comes by?
Surely someone knows how to make a person pick up a ball and take it with them?
Post edited by hrpschrd on
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,725
    I use two and toggle visibility.
  • Steve KSteve K Posts: 3,537
    How about render two clips and piece them together in the video editor.
  • 3DAGE3DAGE Posts: 3,321
    edited June 2017
    Hi :)
    This was done last year to help answer a similar question
    the little man is "always" holding a wheel/cog/thing) ,. and there's "always" a copy of that object lying on the ground.
    One object becomes invisible,. on the same frame that the other object becomes visible.
    So,. in your Broom sweeping scene,. the broom would always have debris attached to it,. and the floor would always have debris lying on it,.
    you animate the broom,. and animate the Visibility / Invisibility of the debris, so that it appears to be vanishing from the floor,. and stuck to the broom.
    Hope it helps :)
    Post edited by 3DAGE on
  • hrpschrdhrpschrd Posts: 180
    3DAGE;
    Did you switch visibilities?
    Bob
    all the time :)
    Whenever I blink,.. everything disappears,.
    Yeah, don't we all!
    Thanks. I think that is an elegant solution even if it leaves invisible objects all around. They don't need feeding . . .
    Bob
  • DUDUDUDU Posts: 1,945
    Cool Andy!
    I use the same trick here:
    Superb DUDU :)
    edited June 2017
  • DiomedeDiomede Posts: 15,467
    +1
    3DAGE said:
    Superb DUDU :)
  • PhilWPhilW Posts: 5,162
    Switching visibility is the usual trick. I cover this in my Animation for Carrara video training, both picking something up and throwing something.
