Skin builder for Genesis 2 Female (Eyebrows)
Hello has anybody had any issues with the eyebrow builder with this script being too high on the face of the Genesis 2 Female? I can't seem to get it to work properly.
  • CybersoxCybersox Posts: 9,960
    SB3 has a slider to adjust Brow Height.  Is that not working?  I can't say I've had any issues with it, but the brow builder is the one SB3 feature that I rarely use since I aready owned Wow Brow, Real eyebrows and a large collection of fiber mesh brows.  If you just can't get it low enough you might want to check your figure's shaping morphs and see if there's some kind of raise eyebrow morph going on there.
  • Oso3DOso3D Posts: 15,123
    edited June 2017
    At worst, you can go in and change the height of the mask in LIE. That would be annoying, but at least you get a lot of control.
    Good luck.
    Post edited by Oso3D on
  • Zev0Zev0 Posts: 7,123
    edited June 2017
    Something messed it up in the new version of Studio. The entire height range is off. Unfortunately Draagonstorm was the only person who had the source code so there is no way I can update or correct the product:( Only alternative is to manually see where the brows would be central, and apply that height setting to all the maps in an image editor.
    Post edited by Zev0 on
    edited June 2017
    Which version does that?  I'm running SB3 V1.2 and DS 4.9.3.166 and it still seems to work fine for me.
    Post edited by Cybersox on
  • SB3 has a slider to adjust Brow Height.  Is that not working?  I can't say I've had any issues with it, but the brow builder is the one SB3 feature that I rarely use since I aready owned Wow Brow, Real eyebrows and a large collection of fiber mesh brows.  If you just can't get it low enough you might want to check your figure's shaping morphs and see if there's some kind of raise eyebrow morph going on there.
    I have wow brow for gensis 3 female do they make one for genesis 2 female?
  • Thanks for the info! I'm not sure how to do these things but I will try them.
    SkinBuilder 3 is not affected, only SkinBuilder 2.
  • BlueIreneBlueIrene Posts: 1,318
    Are we talking Skin Builder 2 or Skin Builder 3 here? I confuse easily :)
  • 2
  • Zev have you figured out any way to fix it? Im not a computer wiz but I can follow directions lol
  • Can anybody tell me other than latics where I can get some fibermesh eyebrows for Genesis 2 female?
    Only way I see so far is to manually open the brow texture maps, bulk shift them lower in an image editor like photoshop or gimp and resave them. Right now their default offset is too high. I will see if there is another solution in my free time.
    Oh, duh... Totally missed that it said 2, not 3 in the heading, which totally threw me since there never was a SkinBuilder 2.  Or did you sneak an extra product in on me when I wasn't looking?
    Nope, at the risk of sounding nit-picky : the product names are Skin Builder Basic and the step-up version Skin Builder Pro, which work with the V5 UV set to cover both Genesis 1 and 2, and have always been referred to prior to thisvery  thread as just Skin Builder, and now there's Skin Builder 3, which works with the G3F UV set.
