Fitting morphs for dialed characters
RAMWolffRAMWolff Posts: 10,382
So I created this nice shape for Dawn in ZBrush but decided to use the Hivewire in house morphs to recreate it to see if fitting clothing MIGHT be better.  I guess it is but one thing about the FBM for Dawn as I could load that in as a hidden follower morph for clothing and make everything look just fine without having my customers dial up a fix morph .... so I'm at a crossroads right now.  How does one make a follower correction morph for a dialed, saved out, shaping morph that contains all those morphs?  I did this for a pair of shorts I made for her but if I use the Petite dial then the shorts slide off so I did the correction morph without the petite morph dialed in and then the shorts just go out.  So how would one, in DAZ Studio, set up a correction morph?  Would I use the Reverse Deformations option in the Morph Loader Pro dialog or is there another way without having to include EVERY in house morph in the clothing pieces.  If it's the latter I may just go back to the ZBrush morph as it's a one shop solution.
Thanks so much
Richard
