Mimic Pro and Poser Pro 2012
csteell_c2893e4ab6csteell_c2893e4ab6 Posts: 542
edited December 1969 in Poser Discussion
Does Mimic Pro work with Poser Pro 2012? I cannot seem to get it work! Cheers
  • edited December 1969
    Im not sure what you are trying to accomplish but Poser has its own talk Designer where you can load an audio file and the model will pronounce it
  • csteell_c2893e4ab6csteell_c2893e4ab6 Posts: 542
    I cannot get any facial movement in either programs with V4. I have all the morphs injected but I still cannot get any eye,mouth or facial movement.Cheers
  • Richard HaseltineRichard Haseltine Posts: 111,666
    I don't have Mimic, so I may be misunderstanding the workflow but, assuming you have to save a CR2 with injected morphs from Poser to use in Mimic do you have Edit>General Preferences>Miscellaneous>Use external binary morph targets set to off? If not, turn it off and resave your CR2.
    Yes all the above has been done! Still no luck. I think I am doing something wrong.Cheers
    You need to buy talk designer assistant 2 to be able to use V4 or M4 in talk designer
  • info_7ab70978f3info_7ab70978f3 Posts: 78
    You need the dmc files for V4 M4 to use Mimic
