DS crashes when rendering Nvidia driver.
paul_ae567ab9paul_ae567ab9 Posts: 231
I'm at my wit's end with one machine that keeps crashing when rendering. Sometimes it renders and I save then crashes. I can live with that. But other times it spends an hour rendering then crashes before I can save the output.  It is always an Nvidia driver causing the fault.
I posted on the Nvidia support forum a month ago and not a single response so I guess their forum is useless.
If someone here has a clue I will post the APPCRASH details. I cannot make any sense of those myself.
If no one replies or has an idea I'm not going to waste time posting a lot of extended info here.
I will offer the basics:
  Problem Event Name:    APPCRASH
  Application Name:    DAZStudio.exe
  Application Version:    4.9.3.166
  Application Timestamp:    585a34ce
  Fault Module Name:    nvoglv64.DLL
  Fault Module Version:    22.21.13.8165
  Fault Module Timestamp:    58df025a
  Exception Code:    40000015  ( also 0xc0000005 )
  Exception Offset:    0000000000fada8e
  OS Version:    6.1.7601.2.1.0.256.48
  Locale ID:    1033
  Additional Information 1:    0a56
  Additional Information 2:    0a56e92f2428f2efec90c3ea9821999b
  Additional Information 3:    f8e1
  Additional Information 4:    f8e178a47b5a1cac91a9dff6ce90463f
I have totally removed and reinstalled Nvidia drivers as well. No help.
Post edited by paul_ae567ab9 on
  • fixmypcmikefixmypcmike Posts: 19,742
    You're on WinXP-64bit, right?  What's the driver version?
  • No Win 7 Home Premium.
    I did some experimenting and turned off CPU in Nvidia render settings and the problem seems to have stopped.  Then I did a test with CPU only and turned off Nvidia GPU and render times don't seem to change much and problem stopped.  Seems if I have both GPU and CPU checked on this machine I get crashes. ( Latest driver version because I just downloaded that and did a clean install )
    On my Xeon machine ( exact same GT730 card and driver no problems ) It has 48GB RAM vs. the i7's 16GB but no onboard video.
