Measure Metrics Issue – Help
I am having problems getting the figure metrics script to enable editing for all measurement that are displayed after applying the Measure Genesis 3 Female wearable, only five measurement are editable. For example I have the ability to change the bust measurement but not the UnderBust measurement or the height and not the waist measurements. I tried using the configurator but I have no clue what to select for the settings.
If anyone knows what is happening and how to fix it, your help is much appreciated.
    It is confusing to use for me too. Some measurement are active and some are not as I understand according to what morphs are available and what morphs are active or not. However, morphs change all the time and the models do to so I wonder it MM still is 100% correctly functioning.
    Also, it restricts the ratio between body parts when you change measures to be something 'humanly possible' and so will change other mesurements to keep those ratios valid. That means MM is not very good to help create comic caricatures. And as you stated it doesn't allow changing some measurements at all, and I'm not sure, I forgot if there is a special way to allow you to change those so here is the help page:
    http://docs.daz3d.com/doku.php/public/software/dazstudio/4/referenceguide/plugins/measure_metrics/start
  • Ryo500Ryo500 Posts: 2
    I would have thought the preset measurements would work with the script, anyway thanks for the link nonesuch00 I will look at it and try figure it out.
  • Richard HaseltineRichard Haseltine Posts: 111,329
    You have to assign a morph to a property before you can edit it. You need to be careful not to set up the measurements to be adjusted and the moprhs used to adjust them so that they conflict. I'm not aware that there's any constraint on the range of possible values - other than anything introduced by having two adjustments work agaisnt each other.
