Is it possible to manage accents in dialog boxes ?
hi,
when I run a script with words containing accent in a dialog box in script editor, everything goes fine
but when I launch this same script with a shortcut, accent is no longer managed
I've tried encodeURI / decodeURI but it's not working
thanks
var message = encodeURI("Le temps n'est pas à 0, relancer le script")MessageBox.information( decodeURI (message), "Temps incorrect !" , "&OK" )
  • Cayman StudiosCayman Studios Posts: 1,145
    The unicode value of à is 224.  So you can use the fromCharCode method:
    var message = encodeURI("Le temps n'est pas " + String.fromCharCode(224) + "  0, relancer le script");MessageBox.information( decodeURI (message), "Temps incorrect !" , "&OK" );
  • thanks cayman for your workaround, I thought there were a more practical solution
    normaly encodeURI should encode the accent and decodeURI decode them
    anyway thanks again
  • morkmork Posts: 278
    edited July 2017
    Interesting find.
    It's a multibyte issue. Javascript natively understands UTF-8, other languages (and apps based on those) do differ, especially the older ones.
    The encoding gets mixed up between "read script file" to "execute script". Why this happens only when you run the script with a shortcut, whereas in the IDE it works, I'm not sure why this happens.
    But I might have a solution for you:
    (function(){UTF8 = {    encode: function(s){        for(var c, i = -1, l = (s = s.split("")).length, o = String.fromCharCode; ++i < l;            s[i] = (c = s[i].charCodeAt(0)) >= 127 ? o(0xc0 | (c >>> 6)) + o(0x80 | (c & 0x3f)) : s[i]        );        return s.join("");    },    decode: function(s){        for(var a, b, i = -1, l = (s = s.split("")).length, o = String.fromCharCode, c = "charCodeAt"; ++i < l;            ((a = s[i][c](0)) & 0x80) &&            (s[i] = (a & 0xfc) == 0xc0 && ((b = s[i + 1][c](0)) & 0xc0) == 0x80 ?            o(((a & 0x03) << 6) + (b & 0x3f)) : o(128), s[++i] = "")        );        return s.join("");    }};MessageBox.information(UTF8.decode("Le temps n'est pas à 0, relancer le script"), "test", "ok", "cancel");})();
    Long story made short - copy that UTF8 block and when you output strings, pipe them through UTF8.decode()
    Post edited by mork on
    edited July 2017
    Is it just me, or is the code block collapsed? That's not very useful :|
    So here again:
    (function(){
    UTF8 = {
            return s.join("");
            return s.join("");
  • Thanks Mork for this code.  It has been very helpful to me.  However, it seems to fail with Japanese/Chinese characters.  Do you know how to fix it?
