DAZ Studio Pro Tip (View-port Performance)
AalaAala Posts: 140
My biggest annoyance when it comes to working with DAZ Studio is that working on its view-port is TERRIBLY AWFUL as soon as you fill your scene with stuff. Today I embarked on a journey to discover how to fix that. And after many trials and tribulations, I had to share this:
Go to Edit - Preferences
Then under the interface tab there's an option called display optimization
Select Best
Click Apply and Accept
You can thank me later. ;)
P.S.
Works on texture view, wireframe view is still quite slow.
  • Nyghtfall3DNyghtfall3D Posts: 817
    Yup, and adding to that, turn off Per-Pixel Shading and Hardware Anti-Aliasing.
    edited June 2017
    How to keep the selection of the cursor, say when you have a scene in the DAZ Barn with lots of mesh, the cursor always wants to choose the DAZ Barn, how to change that to make it easier to select other models in the barn?
    Post edited by nonesuch00 on
  • RobotHeadArtRobotHeadArt Posts: 917
    You can also set Backface Lighting to Off for additional performance but it may cause some objects in the viewport to look weird (they will still render fine).
    @Aala  "You can thank me later. ;)"
    Pretty bold.
    Tenth or so time this tip has been "discovered".
  • AlienRendersAlienRenders Posts: 806
    This is only for OpenGL right?
  • HavosHavos Posts: 5,701
    in the scene tab click the small tick mark for the entry for DAZ Barn and it will become a small x, after this the barn will not be selected by clicks in the main view pane, only via selection on the Select pane
    Ah, thanks!
  • AalaAala Posts: 140
    edited June 2017
    Pretty bold.
    I figured it has been posted many times, but I seriously don't understand why it isn't like that default. If it helps a few people with their workflow, it's worth this all the time.
    Post edited by Aala on
    Aala said:
    Pretty bold.
    The optimal setting varies on different systems.
  • Jan19Jan19 Posts: 1,109
    Thank you. :-)
