(solved) Is it possible to change the internal name of a daz figure (not label) ?
hi,
I would like to change the internal name of a genesis figure but I don't see how to do it and if it's possible
In this example given by the node properties, it's "Genesis3Female_dup_2" I want to change
Thanks
Primary |
Genesis3Female_dup_2 |
Label : |
gina |
Class : |
DzFigure |
Metadata |
Scene ID : |
/data/DAZ%203D/Genesis%203/Female/Genesis3Female.dsf#Genesis3Female |
Content Type : |
Actor/Character |
Compatibility Base : |
/Genesis 3/Female |
Object |
Class : |
DzObject |
Shape |
Genesis3Female_17418 |
Class : |
DzGraftingFigureShape |
Geometry |
Genesis3Female |
Vertices : |
17 418 |
Faces : |
17 000 |
Class : |
DzFacetMesh |
thanks
Post edited by ratus69_c6741fefbf on
ok found it, it was in DzElement with setName( String name ) method
it changes the Primary Name but not the Object name but if you export the mesh, it will use the primary name so it's ok for what I was looking for...
