SKIN MATERIAL / SHADERS
lordgabuxlordgabux Posts: 0
Hi!
We know not everybody has the same skin tone and I'm trying to be able to have characters from different latitudes but I can't find anything to do this except for Carrara Surface and Skin Shaders and I don't know if this can be used with Genesis or even in the Daz program.
I've seen the ethnic packs but that's not what I need.
Help please.
  • Scott LivingstonScott Livingston Posts: 4,352
    edited February 2013
    Hi, lordgabux! Welcome to the forum. :)
    Well, there's two main ways to change skin tone:
    1. Use a different skin texture
    2. Change the diffuse color (instructions below...)
    Using a different skin texture would probably yield better results, depending on what you want to do. There are plenty of characters with various skin tones in the store here. But changing the diffuse color is a valid option also (and cheaper than buying additional characters). The basic, quick instructions for this are:
    1. Select your figure
    2. Go to the Surfaces tab
    3. Select the skin surfaces that you want to change
    4 Change the diffuse color (which is likely to be very light by default) to the tone of your choice
    If you're not too familiar with the Surfaces tab and the procedure of how to use shaders, I recommend taking a look at this: http://www.daz3d.com/forums/discussion/16887/
    For more details about altering skin tone and a lot of other relevant information, see this thread, including links to tutorials of this sort: http://www.daz3d.com/forums/discussion/368/ Look at the bottom of the first post.
    The Carrara shaders you mentioned are for use in Carrara, not DAZ Studio. In DAZ Studio, most characters use the default shader, the Elite Human Surface Shader (EHSS), or UberSurface. All three of these are included in DAZ Studio 4.5 (no need to purchase them). Here's some helpful information on EHSS: https://helpdaz.zendesk.com/entries/20658113-How-to-use-the-Elite-Human-Surface-Shaders
    Post edited by Scott Livingston on
  • lordgabuxlordgabux Posts: 0
    Thank you so much.
    All your information was more than useful! :cheese:
  • Tramp GraphicsTramp Graphics Posts: 2,432
    Also, if you can't afford them, you can also find freebie textures as part of other freebie sets from various sites, such as ShareCG.com .
