RESOLVED: Does This Exist Already: Using G2F textures on the G3M figure?
ArtsyDragonArtsyDragon Posts: 682
edited February 2018 in Product Suggestions
It probably does but I'm not able to find it. Anyone ...? Bueller?
I would like to use G2Female textures on a G3M character I have.
Thanks.
Post edited by ArtsyDragon on
  • ArtsyDragonArtsyDragon Posts: 682
    Bummer .. I guess the silence means 'no' there isn't anything like that out there.
  • nonesuch00nonesuch00 Posts: 18,878
    You'd first convert it to G2M and then to G3M I think is the way it would be approached if it can be done. Look at Renderosity at Blacksmith's Texture Transformer & it's associated add-ons to see if it has a path of conversion to what you want to do.
  • I second @nonesuch00.  I've used Blacksmith's Texture Transformer and it works well.  Once you make the change from G2F -> G3F, you can use the Genesis 3 UV Swap to use it on G3M.
    Thank you so much! :)
