eyes coming out black in 3Delight
Drogo Nazhur
When zooming in close in 3Delight, my character's eyes look normal but when I do a full body render, the eyes are all black -- there is no white portion at all. I need to add that in IRAY they come out perfectly fine in both close-up and full-body renders. Any idea what I need to do to fix this problem?
Did you use Iray material on the eyes in the 3delight render?
there are some basic difference between the materials that Iray and 3delight use. Some of the do render in the other engine others go black or look really bad. So make sure that when you render 3delight to use 3delight materials and iray materials ofr the Iray engine. If what you started with is 3delight you can use the Iray uber base as a tool to convert to Iray. But usually the material look better if designed for Iray as well. Transfering the other way round is more complicated and needs some insight in how the shaders work. I can give you some hints but would need to know what you know already
edit to add a render with what the eyes look like would help as well
