Pins not working on Power Pose Tab
Hello!
For some reason, when I try to double click on the node on a Power Pose tab it does not toggle pins on/off. It used to work but stopped for some reason. I don't remember changing any preferences. Please help!
335 x 566 - 29K
  • Richard HaseltineRichard Haseltine Posts: 112,089
    In the release build or the public beta? The public beta has seen soem major work on PowerPose, so if you are seeing this theer it could be a bug and should be reproted (unless soemone can come up with a setting that affects it - the beta does not inherit the settings from the release build).
  • danygoldanygol Posts: 8
    It's an official 4.9.3.166 release.
    It worked before and just stopped!
    Ok!
    You need to press Ctrl!
    Double-click has never been a shortcut in the PowerPose pane - the beta is expanding the feature set, but still hasn't added double-clicking as a way to interact with the pane.
