Measure Metrics pane not appearing.
Not totally true, it's rather a large pain.  The documentation and YouTube videos show there's supposed to be a separate pane for Measure Metrics, but all I get when I click on the poses or wearables icons and apply them to my figures is a change of the figure's pose and a lot of the XYZ icons that indicate the followers.  No pane indicating measurements appears, it isn't available under Windows>Panes or if I right-click to add a pane.  I installed it through Install Manager first and got this result, then I updated the metadata through Daz Connect.  Still this result.  It shows as installed through DIM and through Connect, and I'm assuming all the files are present.  This is on Windows 10 and DS 4.9.  The docs provided are useless in troubleshooting, so I'm hoping someone else has found a solution for this.
If you need screenshots, tell me what you need to see and I'll post up.
  • Cris PalominoCris Palomino Posts: 13,062
    Reason: You must enter the serial number from your account in order to use the plugin.
  • The BrigThe Brig Posts: 89
    Forgot to mention that I did that, too.
    You must close and restart the application after entering a valid serial number for the plugin; as is indicated in the pop-up message displayed after clicking the Accept/OK button for the dialog.
